UV Light Cured Adhesives
beiland
#1
I saw this question posed on another forum, and thought it was appropriate here.
Have any of you used the relatively new UV light-cured adhesive? As seen on TV is one variety. If so, what were your experiences with it, and what applications worked well or poorly.
#3
My dentist has also used it on my teeth with good results, although he now uses something more "advanced", which actually means more costly. I also had that work done in 2012.
Willie
beiland
#5
From another forum....
Don't waste your money! Typical Chinese made $19.95 type garbage. My wife bought me this stuff as a gift and it was useless on anything I tried to use it on, even some of the things they show it doing on TV. Probably made in the same plant as exploding batteries. ;-)
#9
I finally received a tube of this stuff for Christmas. So far I am pleased with the results. Seems to work as well as CA glue and it doesn't stick my fingers together. My teeth (crowns) that I referenced in post #3 are still working better than the ones that they replaced.
