post your model RR tips........
I never thought of that! Thanks for sharing!
If you have fought with a steam engine that continually derails at turnouts, try this. I have found that the wheels of the lead truck are sometimes flat across the tread. When they come to the points the outer edge of the tread is still resting on the main rails and they fail to follow the diverging route.
Using a Dremel, grind the tread so that it tapers toward the outer end. This will ensure that the weight is carried by the diverging route rails.
Sorry I don’t quite understan what you mean , when you say tread are you talking about the wheel portion that rides on the rail or the flange that catches the rail head inside edge?
WD-40 is not a lubricant it is a coating and a cleaner, when used on moving parts it acts as a cutting oil and will cause premature wear on moving parts it will also chase moisture so can be used to clean electrical connections...
Agreed 100% it is a degreasant and dispersant. It will act as a temporary lubricant but will eat/melt out any grease and will dry out leaving next to none. It is amazing how many people spray it on bike chains, skateboard bearings or anything that moves thinking it is an easy quick replacement for oil or grease. Perfect for cleaning your old rusty cruddy chain but you must oil it after lol :D
If you have masked off some part of a model in order to airbrush/spray or even brush paint and want a clean line or edge, don't ruin it later by pulling the tape up and away from the surface. I've seen this many times, but it can result all too often in lifting the new paint right back off again, and particularly along the newly masked line.
Instead, pull the masking tape ALONG the surface of the model as you remove it. Start at one end, gently lift it up (gently), and then once you have enough off to get hold of it (tweezers can help), fold it back over onto itself and pull the tape along the surface as you peel it off. Along, not up and away.
I would just elevate the throwbar with a shim of thin plastic. If this happens on my handlaid turnouts, I soften the solder and lift the point slightly.
Standard practice for removing locomotive shells is the use of a small screwdriver on either side of the shell
and frame to separate them enough to clear the retaining tabs. Some locos have more than one tab on each
side of the frame and require more than one screwdriver on each side. The downside is as you apply a second
screwdriver on one side, the screwdriver already in in place on that side will want to fall over due to the
reduced pressure and high center of gravity due to the handle.
I use toothpicks instead of screwdrivers. Low mass and no high center of gravity allows them to stay in place.
Their tapered shape allows them to be progressively gradually inserted deeper for the shell to clear the tabs.
They are one of the mostly used "tools" on my workbench.
I have a tip.
No matter the scale, never play in the street!!!! :oops: 🤣:)
Taking a bow. Leaving the chat..........
I use a small “box” plane to form superelevation on cork sub-roadbed. The shavings look like gravel, so i save them to surface driveways and service roads.
When I disassemble an engine, I reuse the plastic trays from ESU decoders. Lots of compartments to segregate various parts.
I use bread tabs to identify wires running under a table.
On homemade timer and signal boards I use craft paint on the terminals. Red is positive green is common, yellow is AC for input which is always on the right. On a relay connection it could the LED color.
Like it. I was thinking of 3D printing some tags. Here we do not get a lot of bread with the tag-things, mostly twist-ems...
I work on computers mostly, but this should translate to trains. I use the 7 day pill containers for screws. The first screws you take off are put in Sunday, the next type goes into Tuesday etc. When you are ready to re-assemble you start at the last day and work your way to Sunday. No lost screws on the bench and floor, and a good memory jog for getting the project reassembled.
