ArtmakersWorlds
Hi all,
Ok, I have a tiny layout going here, 2' round board with a double loop that will fit right under a glass top table. Been buying assorted stuff for a year now, finally getting into this.
But.... Did I buy the wrong rail joiners? I'm about ready to rip my hair out. Time to walk away, find a forum and see if I can get a little help.
So, I have flex track, and went with the code 55 track. Bought a package of rail joiners, and note, already watched a bunch of videos and those folks all have joiners that come in a strip, clip them out and they slide right on. Mine did not, they are all loose, and will NOT simply slip on. (darn already trashed the package too.) These *∞¶• things!!!!!! Will NOT go on the damn track! I have already bent, jammed, twisted several inches of track that had to then be cut off and try again. I only bought enough to do this so gotta stop ruining it.
I have tried filing the ends of the rails on all sides thinking they might "slide" in easier but no. And if I grab both sections of track with pliers and try to force them into the joiner I end up mangling something. Then there is the fact that this flex track seems to only be lightly clipped onto the rail, at least on one side, and after that pops off enough times it simply will not STAY on. Again time to walk away and figure out what I'm doing wrong.
Could it be that I just bought crappy joiners? In which case, someone post what I SHOULD get? Or is there a way to widen the opening on them so they go on the track? My daughter is bringing her soldering gun, I could solder each connection just to be sure it's good, but still need these to clip the track together at least.
BTW... there are NO hobby shops near me at all. Everything I get has to be online. If I could bring these into a shop I would. Can't.
