Track.
I've got a few pieces of Kato track-roadbed (Unitrack) and they don't look too bad. I'm not a serious modeler, I just want something about one or two steps above the plywood under the Christmas Tree gig.
Is Kato acceptable in the Unitrack thing? Seems to work pretty well for me. If Kato is an OK brand, is there one place or another that has a good price on the stuff? I'm not going wild with switching yards and all that, just a couple of ovals with little dipsy doodles to make life interesting. And a single switch crossover to let one train run on the other track.
The passenger is the Con-Cor set and pulled by a Santa Fe warbonnet diesel. Four passenger cars. Do you have to solder the track together for this short a train? Or do separate wires every so often to keep the IR loss down? Pretty much the same thing for the Lemon Grove freight line. Half a dozen cars at the most.
The Del Mar passenger line has a relatively long trestle where a slough off of the ocean passes under the tracks. Do I have to elevate the track to simulate what is in effect a very small dirty salt water lake?
Before I lay the track on the wood laminate, should I paint it a neutral color to hide the wood grain, and what is generally used as the base material on which you build the rest of the scenery?
I'm sure that somewhere there is a complete newbies resource for a lot of these questions, so if any of you can recommend some reading, that would be great.
Thanks,
Jim
Thanks,
Jim
