I think I have a turntable like this one:
http://www.walthers.com/exec/productinfo/933-3171
The number on the base is 7003135\A
It has unreliable slip rings for power to the turntable track, and has a motor. It has plastic bearings, a large black plastic drive gear, a smaller pinion gear on the motor driving a shaft that drives a small straight cut gear that fits to the large black gear.
It appears to be a really old unit that is a little different mechanically from current units at that link.
Unfortunately the low voltage DC motor spins up real fast and then slows to a crawl a few times each second, making the turntable move in jerks. This appears to be a "feature" of the actual motor, not a defect. I say this because the motor, when removed from the gear drive system, spins up and crawls at a periodic rate like a step motor or eccentric gear motor might do.
This is NOT friction or anything, it is a behavior of the motor itself.
Anyway, I want to make this turntable work reliably and move naturally. I have a 1/2 RPM high torque 4-16 volt DC motor that I can use to directly drive the turntable. It has very high torque, and if I short the motor supply leads it acts like an electric brake. It pretty much instantly stops the motor without coasting down very much.
My thoughts are in two areas...
For track connections, I was going to add two beryllium copper spring contacts at each end, and put eyelets in the wall of the turntable base. My thought was to align the eyelets so the spring fingers snap into the holes to both make contact for power transfer and help position the turntable for a rail match. I would, in essence, make the turntable a giant switch with the eyelet being a locating detent.
I could either sense the track electrical connection between turntable rail and selected feeder/exit rail to stop the motor at a desired position, or use an optical device to cut motor power.
Anyone been through this, or is there something to buy that can automatically locate the correct stop position???
Thanks,
Tom
Thanks,
Tom
