traingeek344
My new layout is 12' x 8'. in HO scale. I have two outer loops with switches to change between. I am wiring for DC control. I'm not sure if I should break the two continuous outer loops into blocks or keep as one each loop. the layout consists of a yard area with a car repair and engine house shown on the lower section. The top section will have some industry sidings as well as on the far left and right. All switches are remote controlled. Your suggested blocks are welcome.
Another question is what size wire should I use to connect each block. The wires will be soldered directly to the track and run back to each block switch at the control panel. I understand that 18AWG is the largest size wire that can be soldered to HO track. Keep in mind I may convert to DCC control at a later time.
Any help you can provide will be greatly appreciated by this beginner. I do have some electrical control experience. Thank you in advance for your assistance.
