Greg@mnrr
Section Hand
The points and frogs on my railroad often get dirty and I need a way to clean the turnouts and other areas on the layout without using a larger nozzle on a typical vacuum hose. I plan on using a PVC pipe fitting, end cap, that I can fit on the end of my vacuum hose. I'll drill out the center of the PVC fitting so I can install a tube connector and use a larger plastic tube attached to the connector as a smaller nozzle. The small size of the tube should increase the suction power of the vacuum.
The long tube will allow me to leave the nozzle on the floor and just use the plastic tube to suck out the dirt and debris without damaging any parts of the layout.
What do you think of my idea?
Greg
Greg
