High Speed Kurt
Gone Railin!
Hi All,
I suppose this needs it's own thread.
Is humidity the thing to control moreso than temperature? Reason I ask, I am in the process of finishing the inside of my train room (15 x 25) I am putting kraft faced R-13 and wall paneling up, and installed radiant barrier panels in the rafters which reduces the heat in the building significantly. The humidity stays around 40%-60% due to the wrap under the siding and the insulation. The area above the rafters isnt much at all, so there is not a lot of space to heat. I am going to install a ceiling fan in the middle to circulate the air (I do have a window unit) Do yall think I will be good to go?
Here are some pictures if they come through:
Kurt
Kurt
