tankist
the system i have is MRC prodigy express.
i have bachmann spectrum SD45 with factory DCC installed. it is limited to 28 speed steps, has only light , and dim functions but it works. reprogrammed it to match the 4 digit road number and all is fine. i don't like that it needs to be at speed 10 to start mooving (anything below and its crawling). played with CV and TV values, no change whatsoever. it almost seems like the decoder did not take values but thats not the case since when i programmed ACC and Dec values i definitely felt effect. i also wanted to enable the back EMF (if any on that decoder) but for the life of me i can't find the values table anywhere...
tried installing what i think is basic decoder from MRC. the only marking on the black wrapper is "made in china" but looks just like that one:
http://www.modelrec.com/search/product-view.asp?ID=7736
opened DCC quick plug athearn CF7 and apparently i will need an adapter (don't feel like cutting the harness out) - it asks for 8 in a row plastic connector while the decoder i have is 2x4 pin grid. oh well i thought and moved to Spectrum dash-8. that one has the 2x4 grid. plugged the decoder inn. all went well, loco responded to input, the only issue was no lights. tried to program address on main line, and it didn't take it. just kept responding to address 2.
so i put it onto program track and tried to give it 4 digit adress to match road number. put it back on the line, it no longer responded to address 2, neither to new adress, so i thought the decoder might not support those (which it should). back on program track i sent adress #4. and now the weirdest thing - it does respond but now it just pulsating (3 times a second). the higher the throttle position the stronger it jerks... is it shot?
any idea?
somehow i think i'll need to by proper digitrax decoder (for the athearns for sure)
any idea?
