And now for the good news, Homer. If you studied and understood my previous post, it's time for some basic math........
I just checked the spec's for an MRC Power G 10 Amp Pack throttle (which is supposedly is discontinued and no longer available). Regardless, it's rated at a maximum of 10 amps continuous output at 22 volts max. DC.
Okay now, 10 amps at 22 volts equals 220 watts of power output. Which means we need 220 minimum watts of power input to supply the output.
Since we have the output watts (220), let's divide it by the voltage (120 volts standard household voltage) to arrive at a figure of 1.833, which is the input amps, or let's round it off to 2 amps. So basically, your 10 amp power supply (output) is really only going to draw about 2 amps (input) of household current to power it at maximum capacity. Maybe even a little more amperage due to power consumption, resistance of wiring, etc. etc., but probably not a whole lot more than 2 amps, so we'll just call it 2 amps.
Actually, since we're only using about 2 amps of electricity on the household circuit, then I was wrong in my previous post
- you need to make sure that no more than 13 amps is not being used at the same time on your household circuit, instead of just 5 amps! So overall, I'd say you'd be pretty safe on a 15 amp circuit.
