Double Crossover with a Double-curve Turnout
beiland
#1
I'm proposing to build this particular double crossover arrangement between my 2 mainlines as they enter/exit the upper deck of my double deck layout. Three of the turnouts are Med radius Peco's (nominal diverging radius 30”). The 4th turnout is a double-radius Peco with nominal radii of 30/60”).
I was hoping to insert a very short radius track between the crossover itself and the larger radius of the curved Peco. As I have it mocked up here that short radius piece is 22” radius. Would that work?,...or maybe 24”r piece??
It looks smooth enough to me. I'm just not sure how such a change in radius can effect things?
#2
I certainly like the looks of it. If it all works I think it will be a great addition. I got rid of all my 22r tracks. Short wheel based locos were fine but the long based loco and passenger cars no. I would go as high of radius as you can go.
George
#4
I think it would be fine. As I recall you have 22" radius other places on the layout so it would not be a stand alone pinch point. The curved Peco would act as an easement.
#5
Yesterday I discovered a problem with some of my NEW Peco crossovers. Four of my new Pecos had problems,...2 had plastic joiners in a few of the tracks had 'dips' in them, and 2 of them had little tip projections into the flangeway.​
These were discovered when I experimenting with running a model 6 axle tender over them. Granted the flanges on these wheels were ever so larger than standards these days, but it was just enough to cause them to bump way up in the air as they encountered these blips in the flangeways. And I double rechecked the gauge on these wheel sets, and they were right on.
This is the tender that had the suspect wheels that encountered the problem thru those X crossings. It came with a nice IHC Mehano steam locomotive built in Slovenia.
I won't really describe these wheels as 'cookie cutters', but I guess their profile interacted badly with the defect in those Peco X crossings. They do not seem to have a problem with the std Peco turnouts, nor with any of the multiple Atlas turnouts I had on my old Central Midland layout.
#6
First stage of testing
Yesterday I got one of my DC power packs and several locomotives out to see what happens when I try to run trains thru the 'custom double crossover' I am proposing. I did a rather 'slap it together' job in the interest of brevity, and not wanting to cut up too much track until I arrived at a final solution (so please excuse the blue tape holding things in place temporarily.
Regrettably I continued to utilize that same sort piece of 22” sectional track, just to see what would happen. Not only was it marginal in curvature, but it had sligthy deformed ends I discovered with a close up photo,...here...
What turned out surprising was that all the trains I ran through this route experienced NO derailments or noticeable problems with this short decreased radius track section,...even my Broadway Ltd 2-10-4 C&O T-1.
However the long driver 2-10-4 did NOT like to make the right hand turn after exiting the curved Peco (dbl curved) turnout. Its front driver would consistently jump the frog of that reverse curve.
All the other locos and cars did NOT have a problem here, even the long Bachmann northern 4-8-4 that ran over this route multiple times, slow-fast, fwd-backward, pushing-pulling those double auto racks.
The 6 axle Proto E8 did not have a problem. That IHC tender did not have a problem once I substituted a better Peco short X.
Perhaps I forgot to mention that I replaced the 3 other standard Peco turnouts with the 'large radius size' verses the 'medium radius sizes' I originally sought to use.
I became so engrossed with making this particular route thru the double crossover work, that I forgot to test the other route,...the one with a more direct S curve. I will have to do that today.
I also discovered one other IMPORTANT item,....how lousy those metal track connectors are for transmitting electricity along the rails. They either MUST be soldered, or feeders run to every little section of track !!
beiland
#7
Second Stage of Testing
First order of business was to check that opposite cross-over route,...the one with just the two large Pecos on either corner of the short 24 degree Peco X. All of the locos, including a few new ones when thru this route with no problems. And the long auto racks as well, and that tender as well.
Next I decided to replace that short section of 22” curved track, along with the outer connecting track between the dbl-curve and the straight track portion of the std Peco. Interesting those 2 curved pieces need massaging together. I had to make the short piece of the inner route shorter than what I had yesterday in order to get a decent fit with the outer curve. Trying to utilize a short piece of flex track to make the short curve piece was a real pain in the ____. I'm seriously thinking of going back and redoing it with a short piece of 24” fixed curve track,...shortened to the proper length,...holds its shape better than the short flex track piece. (if the older 22”r piece worked find, then replacing it with a 24”r piece should be just find).
I then tested all those engines on these new curves, and everything within the double crossover system worked find.
Outside of double crossover system I had placed a right hand turnout connected to the other end of the curved turnout. That creates a S turn of its own. I had tried to utilize a 'med size' Peco there, and it caused a derail almost every time with my 2-10-4 steamer. I replaced that with a 'large size' Peco, and the 2-10-4 still has some problems on occasions. I'm going to recheck that tomorrow to be sure my memory is working correctly. All of the other locos and cars worked fine on either the Med of Large size Peco. I'll probably just end up using the large size Peco to be safe,... for this relatively more difficult spot to reach on my layout plan.
#8
Question: Does your 2-10-4 have all flanged drivers or just the end pair? My kitbashed 2-10-4's (from Mantua Mikados) have only the end drivers flanged, with the blind drivers shimmed up .010" off the top of the rails, so they don't catch coming out of sharp curves. I try to avoid sharp S-curves for the sake of 85' passenger cars. Neat-looking track plan. Where the bottom of the flangeways are too deep, I add some ground plastic and solvent, and then file them back just deep enough to clear the flanges.
