Midland Man, glad you like it.
The design was copied almost exactly from MR, where the author chopped up the HO version for the Turtle Creek Central project layout. I copied his cuts, botched a few things, and stuck it together as best I could. (I figure, it's a coal mine, not a piano...
Dameon, the lift out is a great idea. I'll definitely go with that (if only to clean under it... the thing has a way of throwing coal around).
The grading and washing facility is an interesting idea, and another possible client for the railroad.
Off to do some research...
Well, the nearest hobby store is quite a long ways away (I live in the middle of nowhere), and I found that by sifting the ground plastic I could get rid of my main problem with it: the little tiny bits that stick to everything by static electricity. By pre-cutting the plastic before feeding it into the hopper I reduced arm strain a bit, and luckily I'm young enough that my arms didn't fall off.
I'll use the little stuff for truck loads and add it to the ballast around the mine. To my surprise it actually looks reasonably decent.
Enough talk, mock up pics. (Keep in mind that several parts aren't glued.)
I made the open windows by cutting a window or two out of the kit's window strips, cutting and filing it down to where it would just barely squeeze into the hole, then glueing them in place. I think between that and the open doors this thing looks more realistic than it did to start with. The panel lines are cut with a hobby knife, the paint is grey auto primer, and the weathering is self-adhesive weathering powder. (I think it needs more black just to tone it down a bit.)
Pardon my ignorance of coal mining equipment, but... what is this bit? It's chutes under it like it's another filling thing, and the supports are far enough apart for a hopper to get in under it. Some kind of storage? Would this have a track under it?
And a video.
http://www.youtube.com/watch?v=1kDJ5fHHG9M
All questions/comments/criticism welcome, and thanks to all who have helped so far. Without you guys I'd still be mucking around with solenoids and drinking straws.
