HO Scale MILW
A Normal, Regular, Train Fan
So yesterday I picked up a static grass applicator, Woodland Senics, and some 12 MM light green static grass. I only tried a small small area on the layout, maybe 2 square inches, but it did not work so well. I used a tack-like glue and tomorrow I am getting some regular white glue which I will water down. I heard that if you touch the alligator clip on the end while the applicator is on, it will give you a static shock. I touched it to see if it gave me a shock to see if the applicator was working right, and it did not. I also heard the metal stand the alligator clip clips to does not work so well and that a nail or T-pin works well. If there is any advice for when I properly test it tomorrow, please tell me! - Ho Scale MILW
