GN.2-6-8-0
Just received my 3mm golden white LED's from Litchfield Station and have a question about fitting them in a brass steamer.
this will be in a GN. loco in which the headlight casting is quite small, In this application the leads will have to extend through the boiler front to connect with a DCC decoder so my concern is what would be the best way to insulate the leads to prevent short's from occuring? painting them with a good coat of paint might work for awhile but vibrations are sooner or later scratch through the paint,shrink tubing even the smallest diameter would probably need to large of a opening.....any thoughts?
