josephbw
We have a Life Like by Walthers GP-20 at the club that has had issues, been repaired, now has more issues. This engine was bought at a flea market, and we've had it about 4-5 years. Several months ago the engine developed the dreaded split gear lope. I ordered new Athearn gears, bored out the axle hole with a numerical drill bit, installed them, and cured the problem and it ran great for 2 months. Sunday we had an operating session and it started having issues again. When running in reverse the rear truck looked like it was hopping up and down, and running forward it looked like it was hesitating at regular intervals. My first thought was that one of the new gears had split.
So last night at our work session I took it apart again and each of the gears looked perfect, and I could not turn them on the axle. I also checked the gears that drove the axle gears and any other gears I could see, and found no problems. So then I pulled the shell, removed the decoder, weight, and checked the worm gears, ball joints, flywheel, and the rest of the driveline, and could not find any problems there either. I also checked for any obstacles that may have been dragging on the driveline, and nothing there either. I ran it with the shell off closely watching for any interference, and came up with nothing, even with 4 of us closely observing.
Have any of you run in to a similar problem and found a solution? I would appreciate any suggestions or even some silly answers, as I enjoy laughing.
Thanks, Joe
Thanks, Joe
