Hi,
I'm not completely new to trains, but let's say it's been many years since my trains have seen daylight I have HO and Lionel, but I'm focused on the HO for now.
When I put my trains away, I had a very basic 4x8 layout (double oval) with no scenery or buildings. Just a flat layout to run trains. My board was put in storage, moved a couple of times, etc. I finally decided to set it up again and knew I had some damage repair. I cannibalized some of my staging track to repair main line damage. No big deal. I don't have a lot of rolling stock.
My goals. I have about a 7x7 area to work in. Only one side is against a wall, and I'd like to have a hole the middle for access. I'd like to keep a double main line layout so I can run two trains in opposite directions and I'd like to have two levels of track.
I'd like to be able to run two trains in opposite directions on the two main ovals AND I'd like to have the option to run a single train on both ovals with a couple of switches to get the train from one to the other and back.
Questions:
Can this be done with one transformer or do I need two?
I assume I need two so that I can control the speed of each train independently. How do I isolate the two main lines for operating two trains, but combine them for operating one? What is the recommended slope for an HO layout? Ho much clearance do I need to fit one train under another (what's the tallest rolling stock on the market)?
Thanks for helping a reborn enthusiast.
Doug
Questions:
Doug
