Orange Irish
I have recently built an up-and-over dogbone layout in HO with a combo of old (but good shape) code 100 track and some new track, using a new power pack as well. I followed an Atlas diagram to a 'T', and it's been working just fine for a few months. The track has been tacked down on roadbed the whole time, with ballast lightly spray-glued in place.
Two nights ago, after using several new DCC locos, and fumbling through the proper process of reversing directions for them, one section of track has apparently lost power. Two sections of track make up the 'under' dogbone, and the inside section is dead starting just after each switch that leads to it. This section consists of two new 3' sections of Atlas flex track, and a few smaller old but good condition sections. All locos operate properly on all other track sections, but stop after each switch on that section.
The wiring is secure, but perhaps there is a defect I can't see under the insulated covering. Aside from this potential cause, what else could be a reason? There are no differences in rail gaps from the past months (hardly any gaps at all). I made a few errors in learning how to reverse directions, so I caused a short several times, including at the switch leading to the now dead track section. Could a short have damaged the terminal wire which supplies the power to that section? I connected a new terminal wire to the main connector wire, but held the track connecting end very firmly against both rails to test it, rather than pulling up the whole section of track and connecting it normally. The track remained dead, but was that not a good enough test?
Thanks for any assistance or insight.
