I successfully installed decoders in my Proto 1000 R22 subway car and Athearn F7, the latter after having a lot of trouble soldering the left rail lead to the frame. In both cases, I tried installing a new 5mm LED headlight with a pair of 330ohm resisters wired in series. This didn't work.
I used a Digitrax DH165A0 for the R22, and a DH163D for the F7. The locos both operate properly, but because of my trouble with the LEDs, they have no headlights.
I'm not sure if the issue was that I did the install wrong, or that the DCC controller (Bachmann EZ Command) isn't cut out for the job. The headlight issue is more of a concern with the F7 than it is with the R22. If it would help, I can post pictures of the installs.
