I figured out how to make a consist and can even make it so one engine can run backwards however yet i cant figure out how to tell the front engine that it is the front and cant get the horn, bell or lights to work
BTW this is with two engnes that are using Soundtraxx Diesel Tsunimi decoders
I was also going to say that I have added a loco to my sound installed units. My Genisis SD70M UP number 3984 one of the two flag units I have and I am running it with my UP SD45T-2 4794. they make a good pair
I press const ...untill it reads "OLD Const"
I select the address for the "lead LOCO" and also give its direction..then press enter.(note this is the const address to use later.)
then I add the 2nd unit address to the consist...then press enter
when your done with adding locos press "const" then "loco" enter the lead locos address and press enter.
you should have control of the consist and only the lead locos functions should work.
