Brakeman Hal
I see occasional pictures of model locomotives with Walschaerts valve gear with incorrect settings between the Main Rod and the Eccentric Rod connections.
On a real Steam Locomotive, for correct operation of the Valves in relation to the Pistons, the Main and Eccentric rods must be set to precisely 90 degrees apart, or 1/4 turn of the Drivers.
Also, to have the Power Strokes equally spaced between the Left Hand and the Right Hand drivers, the Main Rods between each side must also be set 90 degrees apart.
This will give the proper 4 Chuffs for each revolution of the Drivers: Chuffs 1 and 3 from the Left Cylinder, and Chuffs 2 and 4 from the Right Cylinder.
I occasionally see a model loco with considerably more or less than the 90 degree separation between the connections for the Main and the Eccentric Rods.
This will bother the Purist (like me), but will have absolutely no effect on the running of the Scale Model Locomotive!
Thanks for listening!
Brakeman Hal, age 82 (Steam heritage going back to the early 1940's)
