I picked up a used Athearn Genesis F7 AB set in the earlier CNW colors (not the later mostly yellow scheme). The previous owner had added DCC and led headlights and its currently set up with a double light (cover making it look like an over under light) white LED on the lower light and the upper light is a red LED currently programmed to slowly strobe in and out to mimic a mars light I assume (not direction specific).
What would the correct light configuration (all the lights overall too), color and operation (forward, reverse ect.) be for this setup?
The red LED seems to be fairly well glued in place so I am tempted to just reprogram it to operate solid red in reverse or emergency stop or something that makes more sense if I can't somehow tear it out and change its color (possibly bi color led's I heard about if that would be correct).
If I do get the LED out I may need a new upper headlight lens for that Highliner F7 shell though even that seems permanently glued in, not really sure. I intend to change it to a plugin connection anyways since its irritating to have the wires permanently attached to both the shell cover and the board.
