railfan
junk collector
I have a MRC prodigy express DCC system and was thinking of trying to setup JMRI with it. I'm pretty sure the prodigy exp needs the version three software before it can run JMRI so I will need to make sure mine has V3 or get it.
The MRC cable to go between my laptop and the prodigy box sells for about $45. It has an RJ45 plug like a network cable on one end.....and a typical flat type USB plug on the other end. This MRC cable also appears to have some colored LED's on one end that perhaps indicate activity/throughput or something.
Here is the thing: I have two cables that came with APC battery backups. These cables have the same plugs like the MRC cable for JMRI. They used to call these a serial cable back before they went to using USB. I thought I may have heard this term serial cable used to describe a JMRI cable. I wonder if these leftover APC cables will work?.......or if the MRC cable would be wired differently even though the plugs are the correct ones?
Mike
Mike
