Same Ol' Buzzard
Bill, you posted that the layout is 39" x 11'. Earlier you posted that you had a 15' wall, so I assume that you are centering the 11' on that wall. All good so far. If you are going 39" for the full length, you will have difficulty reaching the back, 30"-32" is preferable. If you can make the layout resemble a shallow "U", with the center 4' a bit narrower, say 32", while leaving the ends at 39" x 39", you should have no problem accessing everything. You may already have this in mind, but your posts are not specific on it. Almost all four axle and some six axle diesels will negotiate 18" curves, but you may have to convert the six-axle ones to a longer shank coupler. Skip 15" unless you cannot avoid it on industrial sidings.
Others have already stated what my thoughts on the Snap Switches are. I cannot comment on a T-1 as I have no experience with steamers. I do DC, but what Iron Horseman posted regarding reverse loops is basically what I have read over the years. Good Luck going forward.
Willie
Willie
