Modell Railroad Links
Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 156
Thread: Help Please....design a dbl-deck layout in its own Hand-House shed
  1. #1
    Join Date
    Nov 2009
    Location
    St Augustine, FL, Khon Kaen, Thailand
    Posts
    1,468
    Default Help Please....design a dbl-deck layout in its own Hand-House shed
    Objective:
    I want to build a double-deck, around-the-wall, peninsula style layout in a 12x16 shed I have prepared for the job.
    I have picked out two plans that I found among many that I had saved over the years from magazines, particularly Model Railroader *. A combination and modification of these two layout plans should produce what I am looking for. I realize there are any number of computer aided programs that have come into existence to help with layout planning, but at my older age, I'm not real excited about taking a great deal of time to learn how to use these computer programs. I'm hoping some folks with that sort of knowledge will come forward and help me plan the layout, and visualize it with 3d images before I begin final construction.
    *I contacted Model Railroader magazine about posting some images of older RR plans they had published in the past, but were not currently available on the internet. They informed me in writing that it would be permissible if it was in pursuit of my own individual effort to design my personal layout, and if I gave them credit where appropriate. So please don't anyone bring up this 'copyright' issue.
  2. #2
    Join Date
    Nov 2009
    Location
    Posts
    1,468
    Default
    Over the years I have seen many really nice train layouts that had to be cut-up (and destroyed) in order to remove them from their home place, due to either the owner's having passed away, or his moving to another residence. Very often they are rather a custom fit in their home built environment, and thus aren’t likely candidates for a new special location. I'm even currently in possession of a very nicely detailed waterfront scene that had to be cut out of an estate sale layout, and I am hoping to incorporate it into my new layout, but I see problems on the horizon.
    With these experiences in mind I decided that I would purchase a stand alone Handi-House shed, and build my new layout in there. Then if I should change residence again, I can simply load that shed onto a trailer and move the whole layout to a new location. Or if I should pass away my wife could sell the layout and shed as an entity, and the buyer could move it to his new location.
    I retired to a trailer home here in St Augustine, and it had an almost full length carport attached to it. I thought why not pull that new shed into the back portion of the carport and take advantage of the extra shade provided by the carport cover over the shed. It was a tight fit, and in fact to get a 12 foot wide shed into my carport I had to move all 5 of its support columns out a distance of 1 foot (had to pour concrete footer for those new column locations). I also had to remove 3 big beams attached to the underside of the shed in order to get enough clearance to fit under the carport's roof (I had initially given considerations to chopping the peak off of the shed), but became convinced I'd rather trim the height by modifying the bottom. I needed only a few inches, but it became a major undertaking. And I did this all by myself at the age of 74 using skid pads I made and a come-along attached to a tree in the back yard.
    Click image for larger version.
ID:	61826Click image for larger version.
ID:	61828Click image for larger version.
    I have now just finished insulating the entire shed and installing a ceiling fan and a small air conditioner. My interior dimensions with the insulation all in is now 11 inches short of the overall dimensions of the 12x16 shed, ie; 11' 1” by 15' 1”
    I want to build a dbl-deck, around-the-wall, with a peninsula layout. At first I was wondering if the peninsula might project out from one of the 'long walls' of the shed, but I am now convinced that the peninsula needs to project out from the 'back narrow wall' of this shed that sits at the opposite end from the big door.
    I intend to have a helix (likely single tracked) to move the trains between the 2 decks. And since the helix’s take up so much room, I intend to make the helix structure in its own 'box' external to the interior of the shed. This will be like a 'winged box' structure hung off a rear corner of the shed, about 5-6 foot in size to house the 26-30 inch radius helix. There will be two small holes in the shed's metal siding to allow the trains to enter and exit the helix. At the moment I am imagining the train will enter the helix at an opening just off center of the shed's wall at the rear of the peninsula, and proceed its upward climb to the top deck, where it will reenter the shed over near the a perimeter (side) wall.
  3. #3
    Join Date
    Nov 2009
    Location
    Posts
    1,468
    Default
    BTW, I have LOTS of ns track, lots of Peco turnouts, all sorts of crossovers, some slip switches, etc to build this layout. Plus I have lots of structures (both unbuilt and some built). I've been collecting this material for a good number of years when I lived up in the Balt/DC/Annapolis area. And I have a wireless DCC system by NCE. (its all stored in a cargo trailer I purchased to move this 'stuff' and store it until I could make use of it).
  4. #4
    Join Date
    Jun 2012
    Location
    Caboolture in SE Queensland, Australia
    Posts
    7,863
    Default
    It's good that the door opens outwards, that will avoid some difficulties.
    CONVICTED SERIAL KIDDER
    I'm lost. I've gone to look for me. If I should return before I get back, please ask me to wait.
  5. #5
    Join Date
    Nov 2009
    Location
    Posts
    1,468
    Default
    I'm hoping to place some removable bridges across that door opening as well
  6. #6
    Join Date
    Nov 2009
    Location
    Posts
    1,468
    Default East to West theme, and Diesel-Steam transistion era
    I have a strong preference for steam engines, but have collected lots of diesels as well. So lets say I will model that transition era were both were utilized. I am also not a strict time frame person that feels a need to model any particular era. I just like the looks of model trains, particularly the highly detailed ones that have come out over the past 15 years.
    I found myself liking those big C&O, B&O, NW steam locos, but also some of the Santa Fe ones. And I couldn't resist a number of those Santa Fe diesels with their marvelous paint schemes that harkened back to when I was a kid. So one my first major layout (the Atlas Central Midland) I ran all of these different lines, and would explain that my railroad went from the east coast to the west coast,...Baltimore to California.
    I'm imagining doing something similar with this new layout,....the lower deck level will be the 'Baltimore' theme, progressing up thru the mountains of Appalachian mountains (coal county) to the upper layer western mountains supporting logging trains, and finally to a Santa Fe train station. The mountainous areas will exist on both the lower and upper decks of the layout at the base root of the peninsula(s),...I thinking...
  7. #7
    Join Date
    Nov 2009
    Location
    Posts
    1,468
    Default Lower Level and first layout exanmple
    So lets start out thinking of the track plan for just the lower level. As I said I have 2 plans in mind that I tend to like very much, but the need to be melted together. The first of these was published way back in 1991, and was called the Anon & Muss.
Name:	Anon & Muss RR, larger size.jpg
    It had a 'blob' at either side of the entrance way to the layout, and another one at the head of the peninsula. At the root of the peninsula it had crossing track configurations that would allow for greater radius turns from the tracks running down each side of space into the peninsula area, ….particularly if I intend to 'squeeze' this plan down into a more overall narrower shape than the original plan. There were a number of these 'crossing tracks' woven in to 'over and under' configurations that might be best handled in a 'mountainous area'......the Appalachians I spoke of before..
    Another thing interesting about this layout design was expressed in the description of its design, … “the notion that's reflected in the premise behind the A&M track plan. You can have easy (hassle free) operation even with several trains running simultaneously on a single track. Make the layout two separate lines. Interconnections between lines would allow the layout to be run as one railroad. Each route could be constructed independently if the lines were judiciously located to each other. ….
    The MUSS loop can be run completely independently of the ANON loop”
Name:	Anon & Muss scematic, larger size.jpg
    I like to run trains, particularly multiple trains of different configurations, and simultaneously. That’s one reason I like this double loop scheme, and it might even be more versatile if I can place a removable bridge across the shed's entrance to the layout.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Anon & Muss RR scematic.jpg
ID:	61832   Click image for larger version.
Name:	Anon & Muss RR.jpg
  8. #8
    Join Date
    Nov 2009
    Location
    Posts
    1,468
    Default
    I'm sorry, I can't figure out a way to delete an attachment (or image) with the software on this site??
  9. #9
    Join Date
    Jun 2012
    Location
    Posts
    7,863
    Default
    I sometimes have difficulty with editing posts in that once I've edited it won't save. But in order to delete an individual picture after selecting the Edit option, which has it's own field with what you have previously posted in it, scroll up or down to find the image you want to delete, place the cursor right next to the right bottom corner of the image and hit the backspace button. That image should dissappear from the field. Then press save. Hopefully that will restore the corrected post.
  10. #10
    Join Date
    Jun 2012
    Location
    Posts
    7,863
    Default
    Looking at the plans you've shown, I would suggest if you do include that center peninsular, you only have it on the lower level. You're going to be pretty cramped for aisle space and to try to double up with that "blob" will be difficult, not just access wise, but viewing also.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
