Modell Railroad Links
Page 1 of 436 1231151101 ... LastLast
Results 1 to 10 of 4360
Thread: Building the Pinacle Creek Mining & Timber Co. RR
  1. #1
    Join Date
    Dec 2011
    Location
    Santee, CA it borders San Diego on the NE side
    Posts
    2,054
    Default Building the Pinacle Creek Mining & Timber Co. RR
    This is my opening thread on the PCM&T. It is a small mining layout in SE Alaska up one of the fjords. It is October 1931. Shown is the woodworking being done over my old N scale layout. This layout will have three levels. The highest level will be reached by a switchback. There will be two mines, a logging camp and a 'Dolley Varden-type' ore tipple. Comments are appreciated. Jim
    Click image for larger version.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Join Date
    Dec 2011
    Location
    Posts
    2,054
    Default
    I'll try another photo.Click image for larger version.
ID:	62090 Coming up is a different screening process that doesn't involve cardboard strips and stacks of folded paper. Jim
  3. #3
    Default
    Nice that you were able to reuse a lot of the existing benchwork. Backdrop is cool. Looking forward to pics of the screen...
    Ian
    Modeling my own reality: Cole River...
  4. #4
    Join Date
    Dec 2011
    Location
    Posts
    2,054
    Default
    Ian, Thank you. Maybe tomorrow. Jim
  5. Default
    Looking good, already has that backwoods feel to it!
    We'll look forward to seeing the progress....
    Questions answered, Answers questionable.
  6. #6
    North Coast Railroad Guest
    Default
    I like the benchwork...Looks like what I need to do.
  7. Default
    Thats alot of elevation... I see your using the WS Foam. Is it easy to work with?
    Tim from Hanover, Maryland ( south of Baltimore )
  8. #8
    Join Date
    Dec 2011
    Location
    Posts
    2,054
    Default
    Tim, Yes, I have use WS Foam on all of my layouts. I only used it on this one because it was left over from my N scale layout. I didn't want the subroadbed nice and smooth like the foam gives you. I used risers and plywood this time. I actually want ups and downs and crooked roadbed this time because that models a mining railroad build mostly by hand and mule teams. It is not perfect, but I like the look. HO trains, my Shay, Climax, and Heisler, will run fine on this layout.
    Now, if I was building a more modern diesel type layout I would certainly use WS Foam Risers. The system is a great way to go. Thanks, Jim
  9. #9
    Join Date
    Dec 2011
    Location
    Posts
    2,054
    Default
    Rico and Devin, Thanks for the comments. Devin this benchwork is the "L-Girder" type of construction. I like it. Large layouts are probably best done this way. They are other methods but I like this one the best. Jim
  10. #10
    Join Date
    Dec 2011
    Location
    Posts
    2,054
    Default
    Here is the idea I came up with while walking through Lowe's garden department. It is half inch square netting material. It is in the wire fencing section. If you notice on the previous photo the cardboard hills where folded in slightly. This gives me and anchor point for the top of the netting.
    I use hot wax to hold everything together. I will post a photo of that tomorrow. This netting feels as strong as carboard lattice and certainly paper rolls. Next I will cover this with Woodland Scenic Plaster Cloth. If you look closely you can see the wax on the cardboard and the track route. Jim
Posting Permissions
  • You may not post replies
  • You may not edit your posts
