Modell Railroad Links
Results 1 to 5 of 5
Thread: Decoders for Kato SD90
  1. #1
    Default Decoders for Kato SD90
    Kato SD90 CP with ditchlights HO
    recommendation for decoder for basic function?
    and recommendation for a sound unit and install hints?
    On the digitrak factory equipped units what version of decoder is installed?
    thanks ,,, Ken
  2. #2
    Default
    For sound, the TSU-KT1000 EMD 710 (the one listed for the SD70). You may have to remove the weight in the top or work around the rear light pipe for the speaker. You may have to add LEDs to the FX5/6 pads for the ditch lights.
    Basic function? A 8 pin DT4 (TCS), a DH165K1 light board (Digitrax), or a MC2H104OP (Soundtraxx non-sound).
    Take care,
    Trey
    __
    Freelance modeling of ICG and SOU in early 1980s Mississippi in HO and maybe O
    Member, SRHA, ICHS, GM&OHS
  3. #3
    Quote Originally Posted by ICG/SOU View Post
    Thanks Trey, I will probably go with the TCS. I wonder if I will have controll over the ditch lights with a DT4?
    thanks ... ken
  4. #4
    Default
    Quote Originally Posted by LotoQuestions View Post
    thanks ... ken
    I seem to remember the SD90MAC had a light pipe from a single LED to both headlights and ditchlights. That being the case, the answer would be a big "no", at least straight out of the box. You'd have to cut the light pipe and add LEDs for the ditchlights.
    Action is Truth.
    Terry
  5. #5
    Default Kato SD90 has a "ditchlight pipe"
    Quote Originally Posted by bnsf971 View Post
    Terry, thanks, appears you are right. I wondered what the funny elongated Y shaped piece with no label on the parts diag was and why there was nothing showing for ditch lights.
    I am impressed with the brightness however it picks up from the light source.
    thanks ,,, ken
Posting Permissions
  • You may not post replies
  • You may not edit your posts
