I used to teach Schedule Management. I used it to some success when building "Giant Scale" RC model airplanes. I'm now building my 4th model railroad. Bench work is up. Ran all the Bus wiring for DCC, Turnout power, LED lighting power. All track and turnouts in place, with Tortoise machines under. All manual switch throws have been done.
So what next?
I have 2 choices.
Paint the track, both ties and rails.
Start Stapling the screen in place for the terrain.
This is a new technique. I first staple the aluminum screen onto the Homosote top layer and bend and contour the screen, putting wood blocks under for some support. Next I thin some drywall mud about 30 percent with water in a disposable roller tray. I use a 'long fur' trim roller to put a thin layer onto the screen. Let the 1st coat dry about 6-10 hours and put a second layer over that. Now its strong wnough to use a dremel with cutoff disk to remove parts of the screen and replace it with carved and shaped chunks of green floral foam, which trees more easily mount.
The tools involved in painting are a compressor and airbrush.
The tools for scenery are a staple gun, scissors, eye protection, gloves, roller pan, and roller with replacement application rollers.
Should I wait until the scenery shell is down and then paint everything?
So what next?
I have 2 choices.
