tortoise switch machine power
Wayne,
I just purchased a pack of 12 machines (cheaper that way) and the directions show three ways to hook them up. It states that 30 switch machines will draw 15-16 ma. at stall (they work by being at a constant stall position when thrown but use very little power while doing so) so they can be powered by, and I quote, "a single 9 or 12 volt, 500 ma wall plug adapter available from Radio Shack."
A second way is to use two similar DC power packs, hooked up together, of not more than 12 volts each.
The third is using an AC source with the voltage being at 14-16.
The three ways show how you can wire it with different switch and wiring configurations. Any of the three will work, it's just which is easiest for you. I'm using the first one since it involves fairly straightforward wiring using DPDT toggle switches. My old transformer (which I use just for my switch machines) has both AC and DC hookups, both of which are adequate for powering my machines.
The directions, concerning power sources, wiring, and switch usage, came with my Tortoise machines when I bought them.
Hope this helps,
Dan
