Single or Double Slip Turnout
So here is my particular situation. I have two spur lines off of the mainlines feeding my peninsula area. It is desired that these 2 entering lines be able to select between either of 2 lines themselves. The most 'compact' manner to do such a thing is a slip switch.
A single slip switch accomplishes just what I want to do,...take the entering train and curve it around onto the same side, or cross it over to the other side. It does this in one single selection of the controller. It can remain on one single selection and do the same thing for trains entering from either track,...cross them over, or leave then curving around on the 'same track'.
Another nice feature of the single slip is that should the train stop, then get reversed while over this turnout, the train will NOT try to pick the opposite track and derail,,,as it might well do on a double slip switch. Is my thinking correct??
Since the double slip switch has 'another set of point rails' at its other end, that ARE NOT always set in the correct position, the train could well back up and try to chose a different route than it came in on. In other words it requires 2 control settings to get the dbl-slip to act in the manner I seek above, ….plus when I change the incoming route I have to make TWO selections to get it to operate like the single slip that I did not have to make any new selections.??
Overall view (sorry, still just a paste in for the peninsula plan as I have not finished final plan for it)
Enlarged peninsula (again, somewhat representative)
Slip switch location
Single or Double
The 2 tracks coming off the slip switch will be feeding the two container unloading/loading tracks located either side of that 'passenger station' in the original Tupper Lake plan.
The track on the left next to the aisle will be the 'escape track' for the locos that pulled the trains into the peninsula area to escape back to the freight yard area or the turntable,...a 22” radius one & a 24” radius one for bigger steamers.
Container crane (block of wood) straddling container tracks
