Good Morning Everyone.......................sunny and clear here in this part of Wisconsin.
Yesterday, I finally unboxed my new Rapido, C&NW Budd Diesel Rail Car (RDC) and put it on my workbench's test track. I could help but notice the great attention to detail with the manufacture applied hand rails, safety chains, window curtains, grill work, interior lighting,classification marker lights and other details that make this an exceptional model. I purchased the sound version with the ESU LokSound decoder. I had the model sitting on the test track for at least ten minutes just taking in the quality of this model.
The model is impressive at just over 11 and half inches long and the stainless steel body is accurately reproduced. Rapido states that the model will run on a 18 radius, but that is very generous and the RDC should be run on a at least 22 inch, if not 27 inch minium radius to look right. Side clearance is also a factor and I'll need to move one utility pole and a spruce tree that the RDC side swipes.
After reading for the second time the instruction manual for the RDC, the manual is both straight forward and humorous at the same time. Rapido believes if you didn't read the manual, don't blame anyone but yourself if you break something. I finally turned on the DCC power and pressed the function 8 button on my Digitrax 402 throttle and the RDC produced the engine start up. First came on the compressors and then one diesel motor and then the second diesel and I actually believe that the unit has two separate speakers since the engine sound seams to be separated with one diesel in the front of the unit and the othr to the rear although I could be mistaken.
The sound decoder produces Lok Sound's usual high quality sounds. The prototype RDC had only four speed notches and so does the model. Out of the box the RDC has three different horn effects one being a grade crossing. The LokSound decoder produces actual rail car engine sounds.
At first when I placed the RDC on the layout t looked liked it was missing other passenger cars and an engine consist. That was until it started moving and the headlights and motor sounds gave it away as a rail car. One word of caution, the RDC is not intended to pull rolling stock since the RDC's two drive motors and drive assemblies are small.
I did other thread on "My Favorite Locomotive" and while this isn't a locomotive per-say, I would place it on the top of my list for motive power! I really like this model.
Sorry, this turned into a RDC Thread but if you are thinking purchasing a RDC don't delay too long since many have been sold out and a limited number are available. I ordered mine in October and just received it.
A doodle bug provides the main passenger service on the C M & N, but the RDC will do mainline runs.
Just a few items to do with the income tax forms and then lunch followed by trains.
Have a great weekend.
Later.........
Greg
