Good morning fellow, 'Tie-Rail Setter & Spike Drivers',
Hi Flo & Francine, How are you both doing? I guess you heard that, Tony [aka Wombat] & Mel [aka Milwaukee Road 113] are both back what a Red Letter Day Indeed! How about some coffee and a Apple fritter sounds good. I buy for everyone else too!]
Per WW: It's Clear at 92.7 °F - Feels Like 91 °F;
Wind are Variable from the SW at 2.7 mph;
Today is forecast to be nearly the same temperature as yesterday.
Today's High 101 | Low 70 °F
0% Chance of Precip.
Yesterday's High 104.7 | Low 63.3 °F
Precip. 0 in
Pressure 29.84 in
Visibility 10.0 miles
Clouds Clear
Heat Index 91 °F
Dew Point 55 °F
Humidity 28%
Rainfall 0.00 in
Snow Depth Not available. Not So! I have 46" of the white stuff accumulating Outside! LoL It makes me fee a little cooler. LoL God I hate this heat!!
Well as I said above today is a great day and one for the record books as two of our members have returned, fantastic. Welcome back to bot.
Tony:, Again, my sincere condolences on the loss of your dear Mother, as well as my prayers for your sister and nephew.
Mel: Very good to see you back too.
>> From the prior Coffee Shop:
Fellas, let's be careful with the medical advice. Eastern "medicine" is especially prone to extravagant over-promises, and as an immigration officer I had to deal with a surprising number of these cancer "cures" from India and China. A quick bit of research revealed that citrus appears to have some promise in this area, but verifiable and repeatable experimental results are apparently still lacking. The following is from Snopes, to which I will add that, if such a simple thing as lemon peel can cure cancer, surely cancer would have been wiped out long ago. Anyway, here's part of what Snopes has to say:
However, the best that can be said at this point is that citrus fruits may potentially harbor anti-cancer properties that could help ward off cancer. No reputable scientific or medical studies have reported that lemons have definitively been found to be a "proven remedy against cancers of all types," nor has any of the (conveniently unnamed) "world's largest drug manufacturers" reported discovering that lemons are "10,000 times stronger than chemotherapy" and that their ingestion can "destroy malignant [cancer] cells." All of those claims are hyperbole and exaggeration not supported by facts.
Beady: While I realize that the information I received from my friend in China may not have scientific proof it actually works per* the other information I received from another source so you can take-it or leave-it, your joice! Snopes also in their very biased fashion, didn't offer any proof or scientific verification it didn't actually kill the various forms of cancer as purported, either! There were positive cases per some group it did indeed work but without going back to try and find that info I don't recall who it was? Snopes, is a husband and wife team that is funded by George Soros and seemed to appear on the scene shortly after oBummer appeared on the scene to refute any negative claims made against him.
I questioned them directly about 'oBummers' birth place not actually having been in the U.S.A. or Hawaii but rather Kenya and their reply stated at the top in bold letters that information was,
False, which most would take as a definitive answer and yet when I read all their manipulative wording below, there about half way through their info in much smaller type was their note that it was
'True', so that let me know that for them to start the Reply of as thought it were,
'False' was highly manipulative and willfully stated so as is their ending above in the quote! I don't trust or believe anything they say as being definitive in the least but rather manipulative BS.
So there's the other side of the coin.
*[>Snopes<a typo]
Ken: I happened to see in a prior post where you said doing scenery causes you some anxiety? It's really rather fun but I'll have to admit I also have my uncertainties about how it will turn out but it all seems to work out to be fine. The nice thing is that it can usually be redone without too much trouble. Even cast resin representing water, can, I believe be poured on possibly Suran Wrap lining the stream bead or pond, I'm not sure about using this to seal the bottom first though, I'd have to check with Woodland Scenics or other Mfg's to ensure their medium wouldn't attack the Suran Warp. But generally doing scenery is very relaxing as your recreating nature and all it takes is a look at areas outside to see what they are like and then it's your decision as to what extent and how much ground cover and foliage should be applied. I've often said that for starters, nothing looks more like dirt than real dirt you've acquired from your location or even a lanscape lot or lawn and garden place which will probably let you sweep up a coffee can or two of the fine dirt that forms around piles of dirt they have. Maybe you even have some vacant lots near by and even the sweepings under door mats provided it dry or dried out later can be used. Heck if you want Cal., dirt I've got plenty.
LoL, some guys even go to the extent to get dirt and rocks from the area they are modeling. I use what's fairly local to me though. Also, it's very easy to make latex rubber molds of rocks you find that look like you'd like to use their rock face look on your layout. I found some really great pieces of rock with a spire type of strata that looks great when molds are made and then Hydrocal is mixed and poured in them and you can also reverse the top to the bottom and adjoin the same mold to get a different effect or even overlap molds by applying a new rock casting while it's starting to set up but still not dry. It really allows your creativity to come out.
I hope all have a great day.
