twforeman Certified Great Northern Nut Jan 7, 2020 #2 Can the spring switch also be thrown to change direction? And if so, is it sprung both ways?
santafewillie Same Ol' Buzzard Jan 7, 2020 #3 Another great video as usual DJ. Interesting fact about the white tie.
Rico BN Modeller Jan 7, 2020 #4 Another great vid DJ! And yes I had a crew freak me out as you described while running thru Symington yard in Winnipeg! BTW I did made a spring switch a while ago using a Kadee coupler spring!
NYC_George Well-Known Member Jan 7, 2020 #5 One thing DJ forgot to mention. You can not stop your loco or train over a spring switch and then backup. The loco or train must completely be clear of the switch before you reverse directions. George
D djstrains Well-Known Member Jan 13, 2020 #6 twforeman said: Can the spring switch also be thrown to change direction? And if so, is it sprung both ways? Click to expand... if reversed, it will be locked with a padlock.
