railBuilderDhd
Hey Folks,
I'm building my home layout (as you may already know) and getting excited as I see the bench work going up. When I was researching before I read that it's best to wire as much as you can before you cover the top with your plywood. This got me thinking about what I need to wire a DCC layout. Being I've only run DCC layouts with modular groups I've never done the entire DCC system myself. So here I am lost on what I need to get in place before I cover the easy access to the lower bench.
Some Background: I have used Digitrax for all other work with modular groups so I have a throttle (Duplex Radio) and I have the Digitrax Zephyr (older non plus) starter set. I know the Zephyr will not power the entire layout so I was thinking I could use that for a section of the layout like the yard and buy what I need from there. My issue is what do I really need to get this layout powered correctly. I need to learn about what I need to get done now. Like I need to run wires for power (done that), need to run a loconet for digitrax and what about extra wires for other accessories on the layout like lights or whatever. Should the loconet not be run along side the power wires? Should I drill new holes for the loconet? Do I need the loconet to just run along the layout or will it be best to follow the tracks like I did with the power wires?
I know this is a loaded post with a lot asked but I'm trying to show what I know of DCC at this point and learn what I can now before I make more work for myself later.
I can post a picture of the layout if you would like or you can see a work in progress of the layout in my other post (http://www.modelrailroadforums.com/forum/showthread.php?23678-My-first-complete-layout-design/page8).
For now I know I'm not placing the reverse track (in green on top of layout) so I'm thinking I'm not needing a reverse loop controller on this layout. I could be wrong, that's why I'm starting this post. I will get a new layout design done over this holiday if I can.
Please ask questions and post any ideas you may thing will help me get this correct.
Thank you and Happy Thanks Giving all!
Dave
Dave
