So, I just looked on the Walther's website. Is there any way you can fit a roundhouse in there? I'm really surprised at how cheap the kits are!
$52 for a 3 stall roundhouse, and $59 for a 3 stall add-on (Shouldn't that be cheaper than the base kit? Anyway...)
Well, I do see one problem, the turntable itself is $350, so that might be a deal breaker. Or space could be an issue.
So I wonder about this... What if you were to buy this kit?
https://www.walthers.com/3-stall-mo...-x-10cm-stall-width-at-rear-3-3-16-quot-8-1cm
$52, so not bad at all. Use the doors and stuff on the front as designed, or maybe even put some brick columns in between. Modify the back walls, but you could use the side walls, front walls interior bracing and pits etc and just build the thing as a rectangle. It would get a bit fiddly on the back wall, and you'd have to either mod the roof or build a new one, but with some creativity you could do it. Bet it would look cool.
