Hawkesburytrain
This is my staging district/block. Total length of tracks is 340' which includes 135' of double main line (staging and helix). Maximum locomotives running at the same time in the staging area would be 4 (2 consist of 2's, hope this is the right terminology)
1) Is this to much for one district booster? I was going to run a separate power for all my tortoises. There will be 18 tortoises, do I have enough power on the main bus to also include all my tortoises or keep them separate from the track bus?
2) Is the booster in the right location based on the bus line (23' either way) or should it be based on the middle section of the main lines which would bring the booster just left of the helix (70' of main line either way)?
3) All my tracks are going to be wired including all my turnouts (Electrofrogs). Should every piece be connected individually to the bus line or could I bring one main feeder to a terminal strip and then connect a few track feeders to each strip and how many track feeders can I bring to a strip?
4) On my main level, I will be using push buttons for my turnouts and since I have NCE, I will need Switch8-Mk2, but for now my question is how far can the tortoises be connected from the board or the push buttons? Basically, can I put everything on one piece of plywood where the booster is and have wires running to every tortoises and push button on the staging area?
5) Is there anything else I should know or do in the staging area?
PS. Please make the answers simple since when it comes to electricity or electronics, I'm clueless
Thanks
Thanks
