I vaguely remember many years ago that there was a way to turn off the juice to a turnout just by operating the points. Lets say you have a spur that you want to power a locomotive and short train in and park, so another loco could use the layout. As I recall, the spur was hot when set to turn out, but deadened when the points were set to straight. Has anyone done this?
Another trick was if you had two switches in line, like for a small siding, the switch motor, manual or power, could be removed on the second switch so the points would float. That way, it was only necessary to operate one switch, regardless if the train was going straight or turning out. Of course, this ONLY works if the points on the second switch are downwind to the direction of travel. Do not run the train against the point ends or you will have a wreck.
This method can reduce the number of powered switches needed and avoids the mistake of throwing the second switch too late. In my present layout, I have this incorporated and it works flawlessly. The only drawback is once you set up this way, the direction of the train can never be changed.
