Greg@mnrr
Section Hand
I have a Digitrax system with a DB 150 and various throttles from a DT402 down the the UT2's. The system runs fine when running trains but when switching to programming the track indicator lights on the Loco Panels do not show power. The throttles lite and show to be active and the programming track shows power going to the tracks when tested. But, no communications between the throttle(s) and the programming track.
No matter what I do the locomotive on he programming track will not respond nor with the track power indicator lites on the LocoNet panels do not light up.
The locoNet panel lights all work fine when running trains.
I changed DB 150 units and had no change. I have DPDT toggle switch that I can switch from the layout track power to the separate programming track.
This is confusing problem that nothing in the Digitrax website or manuals addresses.
Thanks.
Thanks.
