jcarlson1701
Hello All,
I am new to this forum and have re-entered model railroading after a several decade hiatus. For my first setup I have tried to go the most inexpensive route and purchased the Bachmann "Your First Railroad" EZ Track Set along with a Bachmann SD40-2 DCC equipped Loco and the NCE Power Cab Starter set.
The EZ Track set came with 4 remote turnouts (left & right #'s 44561 and 44562 respectively) these turnouts are DC and come with remote switches, however I would like to be able to control these turnouts with my Power Cab.
It has been suggested that I could do this by using something like NCE's "Snap-its" which would be connected to the turnout's existing wiring and then to the Power Cab. I'm a little confused on to how this would be wired...
I understand (I think) as to how the wiring from the turnout to the Snap it would be connected (I assume that I would just use the 3 wire green cable that comes with the turnout that normally connects to the supplied remote switch and instead wire that to the Snap it).
If this scenario is correct, how do I supply power to the Snap it? I only have the 1 power panel that came with Power Cab, so if I have 4 turnouts (which I assume means I would need to have 4 "Snap Its" (1 for each turnout)) How would I attach the 8 corresponding wires for power? I do not want to solder wire to the track if I don't have to. Is there another type of panel that NCE sells to accomplish a nice "neat" connection that I'm looking for? And also, does the Power Cab in it's "starter kit" form offer enough power to drive these turnouts even if this scenario would work or do I need to purchase an SB3 for additional power to the track?
Is this even the proper way to go? As I said I would like to keep the expenses down as I re-enter the hobby and would like to make use of what I already have. Is there a better way to do this using EZ Track? I see that Bachmann does sell "DCC Friendly" turnouts but they are kinda pricey. Or is there a better way than I have discussed (in my confusion) to make this work?
Thank you all for your time and sharing of your knowledge. After I get past this turnout stumbling block I'll be tapping any of yours knowledge for installing a SoundTraxx Tsunami AT1000 in my loco, but one stumbling block at a time!!!
Thanks!!!
Josh
Thanks!!!
Josh
