D&J RailRoad
Professor of HO
I tried for a month to get a Digitrax BDL168 block detection board to work on my layout. One of the mistakes I made in the setup was in connecting a ground wire from to the command station to the BDL168. All wire connections are supposed to be connected to each pair of connectors on the BDL168 except the ground wire. I missed that little note and may have damaged two BDL168s. I sent them off to Digitrax for check up and repair as they still didn't work right after I discovered the mistake with the ground wire.
I am looking at the Atlas and the International Signal System detectors and signal systems which both seem to be easier systems to setup. I saw one demo of the atlas system. Right out of the wrapper, a few wire connections and it was operating a three color signal flawlessly in a matter of minutes. No assignment of address. No board configuration. No loconet configuration. Just a signal control and block detection. I will have an opportunity to see the ISS system next week, then I will make a decision.
As for the BDL168, ISS material can use it for a block detector. I'm a bit leary of this but will take it with me to the demo next week.
One way or another, the layout will have a signal system.
